Key Tumbler Question
Old Mar 8, 2011 | 11:22 AM
NathanS70's Avatar
Question Key Tumbler Question
Hello everyone. I just have a quick question here.
I have a 99' S70. Recently when I turn the key back to shut off the car the key it's self is getting stuck in the tumbler. I'll have to wiggle and tug on it, and sometimes rotate it it to the "on" position then back to "off" before the key will pull out.
Does this sound like a bad tumbler? Is it a pretty easy fix/any documents online showing a procedure? Also would this be something sold only through a dealer?
Thanks.
Old Mar 8, 2011 | 02:20 PM
shadowfist's Avatar
if it is an automatic next time it gets stuck try jiggling the gear selector lever. often times (speaking general automotive here not specifically volvos) the ignition interlock sensor or whatever it's called can go bad. It's what keeps you from taking the key out while the car is in drive.
Old Mar 8, 2011 | 11:38 PM
gdog's Avatar
Spray a bit of graphite based lube in there too; might help.
Old Mar 9, 2011 | 09:31 AM
NathanS70's Avatar
I've tried the gear selector thing, had a Malibu that did the same thing. It doesn't really seem to make a difference when I push on the gear selector.
I'll try the graphite lube and see if it helps any.
Thanks for the replies.
Old Mar 9, 2011 | 12:54 PM
This question is asked almost monthly. The button on the gear selector **** gets stuck in and you have to pull it out or make sure it pops out or your key won't come out.
https://volvoforums.com/forum/volvo-s70-33/automatic-shift-button-sticks-20809/
https://volvoforums.com/forum/showth...ighlight=stuck
Should I continue. They sell them at ipd.
Old Mar 9, 2011 | 12:57 PM
What the heck, here is the video and all:
http://www.ipdusa.com/Volvo-S70V70-P...-128-370-4601/
Grargnash
1998-2000 model year V70
Nov 29, 2015 08:31 PM
fochs
Dec 31, 2014 12:03 PM
PinnacleWax
Dec 22, 2014 03:43 PM
spankey
Dec 28, 2010 05:28 PM
whtemke2005
Aug 6, 2008 01:23 PM
