Low oil shut off
Old Jan 14, 2013 | 11:32 AM
Chris_young0425's Avatar
Default Low oil shut off
I have a 98 s70 na and it has a stuck valve and a big leak in the radiator i was driving and it was low on oil and colliant and shutoff while i was driving it seemed like a blown head gasket but theres no oil in the water im at a loss i dont know much about volvos but i am mechanicly inclined i did a compressionj check the no 2 cylinder has 10 lbs and all others r at 70 pls help
Old Jan 14, 2013 | 01:39 PM
Ozark Lee's Avatar
There is no low oil shutoff short of destroying the engine. Your compression numbers are all very low, they should be in the neighborhood of 200 PSI.
I guess the moral of the story is to not drive when the car is low on oil and coolant.
...Lee
Old Jan 14, 2013 | 11:22 PM
migbro's Avatar
Doood, if you were mechanically inclined you wouldn't have been driving around with low oil and coolant.
The shut off is probably unrelated to the low oil and coolant unless you seized the motor. Did you check the timing belt?
My recommendation? Time to steal a bicycle.
jonqu
Sep 9, 2013 12:31 PM
nitrosport
Mar 12, 2013 06:44 AM
Chris_young0425
Jan 14, 2013 11:09 AM
Pyrate
Jun 15, 2009 02:17 PM
elderzap
Nov 7, 2007 04:58 PM
