Lower transmission line leaking after seals replaced
Old Nov 17, 2014 | 11:11 AM
darrinf15e's Avatar
Default Lower transmission line leaking after seals replaced
My daughters 1998 S70 had a leak on the lower transmission line coming off the radiator. I replaced the seals with IPDs transmission line kit but the leak persists and it leaks at a greater rate. Should I replace the hose, the radiator, or both? Could I plug the ports for the transmission cooler and just delete it?
2005 V70R
2000 C70 HPT Convertible
1998 V70 T5
1998 S70 Base
Old Nov 17, 2014 | 06:06 PM
JamesG's Avatar
You cannot do without the transmission cooler. It is absolutely essential for removing heat from the automatic transmission.
Make every effort to find the source of the leak. Replacing the lower transmission line or even replacing the radiator would be a lot less than replacing the transmission.
pharunk
2001-2013 model year XC70
Jul 27, 2014 06:11 PM
gilber33
Jun 23, 2011 06:23 PM
alpac
Sep 20, 2010 07:36 AM
