Lowering springs question
Old Nov 3, 2008 | 04:26 PM
cdurnal's Avatar
Default Lowering springs question
for other types of cars you can use different cars springs. like you can put stock jeep springs on a suzuki samuri to lift it. is there another type of car that i can buy the springs off of, maybe even stock, to lower my s70 a little bit?
Old Nov 3, 2008 | 05:13 PM
TIPSP's Avatar
Got Boost?
Default RE: Lowering springs question
You will have to measure the hight and diameter and thespring rate to find replacements.
You can cut a coil off your stock springs if you want.
The best way to lower the car would be to just put some sport springs and be done with it.
Old Nov 3, 2008 | 11:01 PM
S70driver's Avatar
1. I have never heard of other car brand springs working or anyone even trying.
2. Yes you can cut a coil off the stock spring, but it isn't a bright idea and can cause problems down the road.
3. Why can't you just buy regular lowering springs for your s70? I mean they do exist.
Old Nov 3, 2008 | 11:33 PM
TIPSP's Avatar
Got Boost?
ORIGINAL: S70driver
AMEN to that....The are only $250-$350, and it is done correctly.
Or you can go the more exspensive route and do coilovers like KW ($2050).
Superfly
Nov 25, 2011 05:39 PM
kh0007
Mar 17, 2008 09:16 PM
hauoli96734
Suspension
Aug 14, 2006 03:24 PM
hauoli96734
Aug 9, 2006 11:18 AM
ludeless
Nov 23, 2005 08:14 PM
