Mass air flow sensor- s70
Old Sep 21, 2011 | 06:42 AM
mourassa's Avatar
Banned
Default Mass air flow sensor- s70
If I remove the connector on the MAF sensor while the car is running then I put it back,should the car stall or keep on running.
I am trying to Isolate a problem and I want to make sure the MAF is not the culprit.
help anyone
Old Sep 21, 2011 | 04:16 PM
It should keep running. It will also toss a CEL. What problem are you trying to isolate?
Old Sep 21, 2011 | 10:08 PM
mourassa's Avatar
Banned
When I do that the car Stalls,does that mean the sensor is Bad.or can an Exhaust leak have the same effect
problem with my car running poorly.
Old Sep 22, 2011 | 05:38 AM
I'm not sure. I've had cars run with them disconnected so maybe I don't know what that would mean. I would guess that it will stay where it is when you pull the plug on it.
What codes do you have in the OBD-II port?
Old Sep 22, 2011 | 05:54 AM
mourassa's Avatar
Banned
thanks,but maybe you are not even reading what i asked correctly.
The car starts if i disconnect it,It only stalls when the car is Running,unplug it and then when I plug it back that,s when it stalls.
mourassa
Oct 25, 2011 02:35 PM
jerryman
Oct 28, 2006 07:35 PM
volvogirl850
Sep 23, 2006 03:27 AM
reg
Jan 1, 2006 11:41 PM
floryed
Apr 14, 2005 10:51 AM
