No ground at ac relay
Old May 4, 2010 | 10:46 AM
skyjack28's Avatar
Cool No ground at ac relay
I have a 1998 v70 that the ac is not working. I do not have a ground at the ac relay, it does have a full charge and I jump the low pressure switch. The light is on the control panel. Does anyone know where this ground signal comes from.
Old May 4, 2010 | 11:21 AM
SVTfocusO3's Avatar
Well, there looks to be 3 relays controlling different things, one is for the a/c clutch, the others are for grounded through the CCM and ECM it looks like. Not sure which relay your checking or if you have Electronic or manual climate control.
Old May 4, 2010 | 11:26 AM
skyjack28's Avatar
Its the relay for the clutch, I can jump 30 and 87 and the compressor works but no ground signal at 87/85. It has a manual system.
Thanks
Old May 4, 2010 | 12:05 PM
SVTfocusO3's Avatar
87 wont have a signal, so there is no problem there. PIN 86 should recieve power from a fuse, which should be ok, so 85 is most likely your problem which is ground from ECM and one pressure sensor and one pressostat (switch) are part of that, but you may want to pull the ecm fuse first and/or disconnect the battery, and wait 15 minutes and see if that helps. ECM codes will prevent operation, but i may be the CCM. Good luck
Old May 4, 2010 | 02:53 PM
skyjack28's Avatar
Disconnected the battery and now is working. I will see how long, I would think that the fault is still there. Do you think this means that the control unit is good?
Thanks
sleech
Jan 25, 2020 05:07 PM
phaedrider
May 5, 2017 04:42 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
Cypress
Dec 6, 2004 03:17 PM
teamlfr
Mar 7, 2004 12:48 AM
