noise from the rear suspension
Old Dec 1, 2010 | 08:33 PM
kennedy759's Avatar
Default noise from the rear suspension
2000 s70 gtl, when it is cold out, there is a noise coming from the passenger side rear suspension when I hit a bump, it is a squeaking sound as the shock moves up and down, once it warms up it is not so much, what should i look for?
Old Dec 2, 2010 | 08:40 PM
kennedy759's Avatar
pulled the carpet up and the upper shock mounts look ok, also the bump stop is in place, i wonder if the shock is wearing out?
Old Dec 2, 2010 | 11:17 PM
akem21's Avatar
I had a similar issue, but mine would squeak when I pushed down on the rear of the car and I found out it was just components of the parking brake.
Old Dec 3, 2010 | 02:56 PM
kennedy759's Avatar
what parts of the parking brake?
Old Dec 3, 2010 | 03:03 PM
akem21's Avatar
Not completely sure, but I'm guessing the pads and springs which are in the "drum" of the rear disc brake. You'd have to remove the caliper and brake to get to it.
Old Dec 3, 2010 | 03:25 PM
kennedy759's Avatar
how did you know it was the parking brake, and did you fix it?
Old Dec 3, 2010 | 04:52 PM
akem21's Avatar
Because it would only do it it when the parking brake was engaged. I didn't do anything to fix it either.
Old Dec 3, 2010 | 08:17 PM
kennedy759's Avatar
mine does it while driving, and not using the parking brake
AnEskimo
Jul 16, 2013 10:27 PM
iceracer46
Nov 8, 2011 09:32 PM
rae8525
Jul 25, 2009 08:28 AM
costa993
May 7, 2008 10:41 PM
gwlorchard
Apr 7, 2008 06:07 PM
