OBD Codes - Engine problems?
Old Oct 13, 2009 | 03:23 PM
thedigid's Avatar
Default OBD Codes - Engine problems?
I pulled two codes from my 99 s70 glt the other day when the check engine light came on. I reset it and the light came back on 2 days later with the same codes. Anyone have any advice on what I can do to fix this on my own.
The codes are:
P1171 - Fuel Adaption, Bank 1
P0013 - Exhaust Cam Position Actuator Open Circuit - Bank 1
I was reading about P0013 at http://www.engine-light-help.com/P00...ine-light.html which hints at a VCT circuit
Someone was saying that P1171 could be related to
air leakage, high fuel pressure, leaking injectors, defective Mass Air Flow (MAF) sensor or defective heated oxygen sensor (HO2S).
Not sure how the two codes are related since they both fire together.
I've recently been having some issues in the morning when the car is cool with some hesitation of the engine not being able to exceed 2500rpm. After about 15-30 seconds to revving the engine it goes away and I can drive normally.
Thanks
Old Oct 13, 2009 | 07:50 PM
Hard to say how they are related. Did you check for vacuum leaks yet?
Has the timing belt been replaced lately?
Old Apr 30, 2011 | 09:48 AM
e573gr's Avatar
At a loss, I have a 2001 C70, automatic, 2.4 turbo, OCB code P0013, Exhust Camshaft position actuator circuit / open bank 1, has 93000 miles, changed all itmes with timing belt, replaced camshaft position sensor, and the code still shows, sometimes it resets itself, then a few day later comes back, any suggestions, on the problem
Old Apr 30, 2011 | 10:03 AM
It might be off by a tooth or so on the timing belt.
Old Apr 30, 2011 | 07:28 PM
thedigid's Avatar
I replaced my MAF sensor and also I had a stuck solenoid on my Cam Adjust Solenoid Actuator(not the sensor). Replaced the solenoid (had a core charge) and no more engine codes for the past year.
phiber
Aug 27, 2008 07:36 PM
air force rascal
Apr 22, 2008 10:47 PM
Jamez2u
Oct 1, 2007 06:34 PM
volvo850sdca
Sep 21, 2007 11:18 PM
justin
Mar 15, 2006 01:29 AM
