Octane Booster and gas treatment
How about u keep your advice to yourself,I doubt you know anything regardless.
Good luck fixing your car (that you broke by trying to improve it..) and thanks for the feedback; we will keep our advice to ourselves.
"After I put in a bottle of Octane Booster and gas treatment,I notice that the car is running a little rough,any Suggestions."
By adding an Octane booster (the most popular being specifically branded "104+"), your fuel now carries an Octane rating that is too high, which means that it is burning too slowly. Your ECU is unable to advance your ignition timing enough to compensate, so you are running rough.
Suggestions?
1) If your car was running normally before you decided feed it the extraneous chemicals, put in some regular-grade, 87-octane gas in as soon as you can. A few gallons should do the trick, and bring your fuel's octane rating back down to within normal operating parameters. You want it to be 95 at the very highest. If it had a full tank at 104, earn yourself a gold star and do the math as to how much 87 you should add before realistically expecting results.
2) Stop being a dick to the people you asked for help. You basically committed a faux pas akin to walking into a doctor's office and saying "I just finished dinner and now my belly hurts." Then you get all defensive when the doctor asks you what you ate... not cool.
Cheers,
LG
Suggestions?
Cheers,
LG
