Oil Change
Old Jun 5, 2006 | 08:52 PM
Nand12's Avatar
Default Oil Change
I am planning to do an oil change on my 1999 Volvo S70 non-turbo. I already have the drain plug washer and the Mann W917 oil filter (fcpgroton.com). I was wondering what size the drain plug is so I can buy the appropriate wrench. Also where is the best place to jack up the front end of the car? Thanks very much.
Old Jun 5, 2006 | 10:07 PM
Default RE: Oil Change
The drain plug is a 17MM.
You can jack it up from the Subframe if you want to in the middle in the front.
Old Jun 9, 2006 | 10:44 AM
Nand12's Avatar
Thank you very much for the quick reply. Did the 1999 non-turbo S70 (2.4 L) do away with the conventional oil filter and switch to the filter inserts or was it just the turbo models?
Old Jun 9, 2006 | 05:57 PM
S70driver's Avatar
If you haven't already switch over to synthetic.
Old Jun 9, 2006 | 09:57 PM
99 was a split year. Then turbo I believe have the metal and the Non-turbo have the cartridge.
gr8lady
Jun 4, 2009 01:29 PM
Squiggy
Apr 18, 2008 04:25 AM
Mnvolvo1
Mar 25, 2008 08:42 PM
NCS60
Apr 5, 2007 12:53 AM
nationm
Feb 12, 2006 10:09 PM
