OIL in distributor cap,TECH please help.
Old Mar 12, 2011 | 02:06 PM
chachouu's Avatar
Banned
Default OIL in distributor cap,TECH please help.
I have a leak ,Oil is coming oil inside my distributor cap.
is there a rubber seal in there that might need to be replaced
Old Mar 12, 2011 | 02:10 PM
Yes the rear cam seal is leaking and needs to be replaced.
Old Mar 12, 2011 | 02:48 PM
chachouu's Avatar
Banned
Thanks for your prompt response TECH.
How hard is this to replace myself.
can i see it after i remove the distributor cap and rotor
Old Mar 12, 2011 | 03:15 PM
It is not that bad. After the cap and rotor are out you need to remove the plate that holds the rotor. It is 1 10MM bolt then you can swap the seal out.
Old Mar 12, 2011 | 03:32 PM
chachouu's Avatar
Banned
Thanks again tech.
RIGHT BEHIND the distributor cap mounted on the engine there is something round with a wire it look like there is a seal inside of it as well.
What is that called.
Old Mar 12, 2011 | 04:33 PM
Your welcome!
Old Mar 12, 2011 | 09:27 PM
It's called the cam shaft sensor. Here is my instructions on replacing them:
http://atthetipwebs.com/technologyin...ear_s70glt.htm
Old Mar 13, 2011 | 09:24 AM
chachouu's Avatar
Banned
Thanks RSPI.
any idea where I can buy that seal inside the sensor.
I was able to find the one that goes behind the distributor cap at a local auto parts but not this one.
Old Mar 13, 2011 | 09:32 AM
They are both the sane cam seal.
Old Mar 13, 2011 | 09:48 AM
chachouu's Avatar
Banned
Thanks tech.
so buy that same one and It will fit inside the sensor
Old Mar 13, 2011 | 10:06 AM
Yes it is the same part number for both seals. You will need to remove the sensor and the plate under it.
Old Mar 13, 2011 | 01:11 PM
chachouu's Avatar
Banned
Thanks,will let you know how it goes.
Old Mar 13, 2011 | 04:04 PM
Chchouu, I wouldn't suggest using after market seals. Our car had after market seals in there and they were leaking. Most post I have read suggest that after market seals do NOT last as long as OEM seals. Also, make sure your PCV system is not plugged up or you may find yourself repeating this job soon, or worse yet needing a real main seal because your cam seals are no longer the weak point.
Old Mar 14, 2011 | 09:34 PM
chachouu's Avatar
Banned
I cleaned out the PCV and the flame trap,no smoke from my dip stick,so i doubt it,s plugged.
I am changing it tomorrow so I,ll see how it goes.
Old Mar 15, 2011 | 09:39 AM
chachouu's Avatar
Banned
I can,t remove the rear main seal
Is there a tricky way or tool that I need,flat screw driver doesn,t help
Old Mar 15, 2011 | 11:55 AM
Not really. I had to dig at it with the real small screw driver I had in my instructions, are you using one of them? See the picture in item 21.
Old Mar 15, 2011 | 12:26 PM
  #17
chachouu's Avatar
Banned
I have one but it,s not doing the trick
Old Mar 15, 2011 | 09:51 PM
  #18
They can be a pain to get out.
Old Mar 16, 2011 | 10:09 AM
  #19
I had a hard time getting one or two out. The other two were blown out so it was easy. Just have to keep diging at it.
jonhall
Sep 29, 2011 08:43 PM
KarenLR
Aug 24, 2010 09:02 AM
calebfrida
Aug 23, 2009 10:31 AM
Trace
Aug 17, 2009 11:07 AM
ShaginWagon
Jun 4, 2008 09:44 AM
