Oil Pan made of Aluminum? Weld up hole.
Old Jan 29, 2008 | 04:34 PM
kursed56's Avatar
Default Oil Pan made of Aluminum? Weld up hole.
Hello, new guy here.
I have a 1998 S70 with a punctured oil pan. Im not sure I want to pay the $900-1200 replacement cost of swapping out my damaged pan so I was wondering what type of material the pan is made of.
I may try to just have it welded closed if its possible and th ehole isnt to large.
Thanks guys!
Old Jan 29, 2008 | 06:25 PM
Default RE: Oil Pan made of Aluminum? Weld up hole.
Yes it is aluminum.
You might be able to get it welded. But you will haev to find someone that weld aluminum.
Old Jan 29, 2008 | 08:04 PM
Eric J's Avatar
Tech's right. Look for someone that can 'heliarc' or 'TIG'
Old Oct 18, 2016 | 01:53 AM
MSGTUSMC's Avatar
I had a whole in my 5-speed tranny case, aluminum. I got an aluminum washer about the size of the whole. Cleaned the whole outer surface. Applied JB Weld stuck washer to fill in most of the whole. Applied JB Weld to washer whole. Let it stand over night. Filled tranny with fluid. No leaks. Drove vehicle 2 yrs. no problem.
Vmax
Mar 16, 2014 04:16 AM
Pmauch
Feb 22, 2011 06:46 PM
vjaneczko
Oct 7, 2010 05:34 PM
Keith Tobberman
Nov 26, 2007 12:35 PM
bagelluvr
Jul 20, 2007 09:21 PM
