outer tire wear
Old Jul 15, 2008 | 06:02 PM
slickpartner's Avatar
Default outer tire wear
Hello all. I now have 154k on my 2000 s70, when I looked at my tires today I noticed both of them were worn badly on the outside edge. The previos owner told me I may need some outer tie rods soon, but that was about a year ago. Is that what may be causing this wear? I had a alignment about 9 months ago.
Old Jul 15, 2008 | 06:11 PM
samadkins29's Avatar
Default RE: outer tire wear
outer tie rods simply make the wheel bounce straight up and down when you hit a bump. If your tie rods out out you will hit a small bump and it will be very loud since the wheel is bouncing all over. I would get the tires rotated first then see if the front ones wear the same.
Old Jul 16, 2008 | 05:28 PM
Ok. Will do. What suspension parts are common for wearing out that may cause this.
Www pp p
pP problem
madymo3d
2001-2013 model year XC70
Jun 5, 2014 02:22 PM
Will630
Jan 14, 2011 12:25 PM
Will630
Dec 31, 2010 11:25 AM
heyitsomid
Oct 11, 2008 06:46 AM
kcw12
Jun 10, 2008 08:48 PM
