P1672 camshaft reset valve?????
Old Jul 21, 2010 | 10:27 PM
DontaviousJones's Avatar
Exclamation P1672 camshaft reset valve?????
On my 2000 s70, non turbo 5speed auto, i get a code p1672, which is referred to everywhere as a "5v low voltage". On a few websites, they have mentioned as a camshaft reset valve, aka the cvvt solenoid. Now I know I need to replace the o-rings in the oil pan, as if my idle briefly dips below 500 rpms, the oil light flickers. Car has 145k miles, replaced 5 spark plugs less than 1000 miles ago, i go about 8000 miles between oil changes but always mobil one, did the t-belt and all components at 103k, runs great, over 30 mpg on the highway, sometimes has a rough/low idle upon start up, primarily when cold, occasional i will start it it will turn on, then immediately die, very rarely but some times have to crank it a few times. Should I try to clean the cvvt solenoid, i plan to do the oil pan o-rings in the next month or so. Anything I can test or look for?????
Old Oct 3, 2011 | 11:10 AM
4daluv's Avatar
Default p1672
did u ever get this figured out on your volvo? i'm having the exact same issue on my 2000 s70...... please let me know if u found out anything, i cant find sht out bout this p1672 no where and apparently none of these mechanics can figure it out either...... let me kno...
rmc2010
Dec 5, 2016 11:05 PM
rainier34
Dec 5, 2016 11:03 PM
smithnr
Dec 6, 2007 08:51 PM
98xc70nny
Oct 19, 2007 11:51 PM
hordezla
Aug 20, 2007 08:45 PM
