Dangers of Leaving Camshaft Reset Valve
Old Nov 26, 2007 | 06:20 AM
smithnr's Avatar
Default Dangers of Leaving Camshaft Reset Valve
I took my 2001 S40 into the shop 4 months ago with a CEL and they mentioned I needed to replace the camshaft reset valve. I decided to try switching to synthetic oil as I've heard the oil additives could clean the valve and the problem will solve itself.
Anyone know the dangers of not fixing this problem? The car still seems to drive fine with no problems in the last 3-4 months.
Also, if I were to fix it, does anyone besides the volvo dealer sell a new valve (or a VVT valve...as I'm assuming the CRV is in the VVT unit).
Old Dec 6, 2007 | 08:51 PM
SWEEDWIZ's Avatar
Default RE: Dangers of Leaving Camshaft Reset Valve
You could run into driveablity problems down the road which could lead to more bigger problems. The check engine light also will be on all the time with DTCs for engine misfire. The best advise is to get the solenoid and the unit (pulley) replaced if you plan on keeping the vehicle. When you are replacing it go ahead and do the timing belt as well. Good luck.
rmc2010
Dec 5, 2016 11:05 PM
rainier34
Dec 5, 2016 11:03 PM
DontaviousJones
Oct 3, 2011 11:10 AM
kennedy759
Aug 26, 2011 06:38 PM
98xc70nny
Oct 19, 2007 11:51 PM
