Parts Suggestions
Old Jul 13, 2020 | 12:09 PM
patcal's Avatar
Default Parts Suggestions
Greeting all,
My first official post. Now that I have my S70 for a day, things I need are coming to light. I need rear brake pads & struts all around. I have heard Volvo's are finicky when it comes to electrical things. What brand pads & struts would you recommend? As far as the struts, I am not a performance oriented guy. I want safe & reliable. Thanks.
Old Jul 14, 2020 | 08:41 AM
Psaboic's Avatar
Check IPD.com, FCP Euro.com, or Rockauto.com You will find endless choices.based on your budget If you are going to do brake pads, I suggest changing the rotors at the same time. Yes, Volvo's are kind of finicky, but mostly ignition parts. Always go with OEM spark plugs, or at the very least NGK, Otherwise, I have run into minor issues with misfiring.
Old Jul 14, 2020 | 09:35 AM
patcal's Avatar
Thanks. I went with Bosch pads. What about light bulbs? I've read about tail light issues. My bulb out indicator flickers sometimes when I apply the brakes. All bulbs are working.
Old Jul 16, 2020 | 08:38 AM
Psaboic's Avatar
Never had a serious bulb issue. I would remove the bulbs, clean the connectors and make sure the bulbs seat in the connector tightly.
Old Jul 16, 2020 | 10:27 AM
patcal's Avatar
Funny. I am old VW aircooled guy. First thing after buy one was remove all bulbs & fuses & clean them. Thanks.
AlanS
Jul 16, 2012 11:16 PM
962ym
Jul 19, 2010 09:30 AM
RedBrick
Suspension
Oct 3, 2006 07:53 PM
jcmartin
Feb 8, 2006 01:02 AM
