Passenger Door Lock
Old Dec 15, 2007 | 10:45 AM
jonnybobs's Avatar
Default Passenger Door Lock
Hi All,
I'm New here.
I have a Volvo S70 1998 and something odd happened today. I went to unlock my car with the Key and noticed that the passneger side did not unlock. If Iopen it by hand and the lock with the key then the button goes down.
I do hear the motor activating (I think) when I tryto unlock but the button stays down. Any Ideas anyone?
Many Thanks indeed.
Old Dec 15, 2007 | 10:47 AM
samadkins29's Avatar
Default RE: Passenger Door Lock
plactic **** is broken. Dorr should still unlock, it just wont look like it is unlocked.
Old Dec 15, 2007 | 10:49 AM
jonnybobs's Avatar
I had the door card apart and everything looks fine. Door **** does go down. If key used the door remains locked.
Old Dec 15, 2007 | 10:59 AM
so the motor goes but it isnt poping the lock up?
Old Dec 15, 2007 | 11:10 AM
jonnybobs's Avatar
Yup. Seems so. As said, it does still go down!
Old Dec 15, 2007 | 11:15 AM
prolly need a new lock motor.
Lets see what some other people have to say first before you start ordering. Im off until later.
Old May 28, 2008 | 08:19 AM
usedS70's Avatar
I have the opposite problem. When I lock the doors, the door lock activates, the plastic **** goes down on the passenger side door, but its not actually locked. It looks like its locked through the window, but you canopen the door. I thinking its a part between the thedoor lock and motor.
Old May 28, 2008 | 09:13 AM
jsj_297's Avatar
Definatley replace entire locking mechanism, Ive done it twice for my s70 already, I have had it six months. There not to bad to change, but a little costly, but it will fix the problem.
Old May 28, 2008 | 08:36 PM
usedS70's Avatar
Okay i'll change it. where did you get your part? cost? How do I take the inside panel off with out wrecking it. I don't see any screws. Must be push pin type. I'll take any help I can get. Thanks!
Old May 28, 2008 | 08:49 PM
There is one screw under the cover where you grab to close the door.
Also the trim ring around the inner door handle comes off.
Then clips hold the rest of the panel in but be careful pulling on the panel. They are well known to come apart.
The inner part seperates from the outer part. But you can glue it back together if it comes apart.
Old May 28, 2008 | 11:11 PM
jsj_297's Avatar
Hi again,
Mine were both rear locks, like tech said just be careful, mine came apart with light prying with a medium flat head driver. I got my parts from salvage yards, tyl. S70 driver has some resource links on the main S70 forum page. Im sure one of them will have it. It isn't a too bad of a job to do yourself. Let me know, I can help you from memory if need be, I just did one last month. lol p.s There is a cover on door with a hidden screw for the lock assy. That got me the first time.
Old May 29, 2008 | 10:26 PM
dkbmx8485's Avatar
maybe this can help...
http://www.youtube.com/watch?v=LreeVUCemrw
Old May 30, 2008 | 07:59 AM
jsj_297's Avatar
Nice find DK! Man I sure could have used that the first time I did one.lol
Vee70
Nov 19, 2009 01:49 AM
Sublimer79
Oct 19, 2009 06:26 PM
J Dubb
Oct 14, 2009 11:58 PM
W35
Apr 29, 2009 09:44 PM
Barnaclebill
Jan 22, 2009 08:03 AM
