power antenna mast
Old Mar 30, 2009 | 04:47 PM
s70_t5_1999's Avatar
Default power antenna mast
i just got my new power antenna mast from FCP groton today. took the entire motor out, but i can't seem to get the mast out of the motor. they sent me directions for a 740... i think its a little different though.
Old Mar 30, 2009 | 06:49 PM
Johnny Mullet's Avatar
I had a customer with a broken mast on a S70 and after parts and labor was added up we decided on an aftermarket. $19.00 and about 30 minutes of work. I fumbled with the old one for an hour trying to get it to work, but never figured it out. Sorry, I can't help, but thought I would chime in.
Old Mar 30, 2009 | 07:08 PM
the instructions say to pull out on the mast and it will come out... but it won't budge. my car has a diversity antenna somewhere which is activated now because of this being out and the signals seems to be better without this antenna. but now i have a hole there and i have to fill it with something (that's what she said!) so its gotta go back in regardless. if anyone else could help here that would be great though
Old Mar 30, 2009 | 08:37 PM
You get it yet?
Old Mar 30, 2009 | 10:42 PM
i finally got the new one on, but it comes out when its all the way up! and the teeth keep getting jammed inside the motor. i think theres a plastic part missing inside, so i might need a motor. i'm gonna leave it disconnected for now since its loud anyway, and maybe someday i'll come by a motor cheap. at least i have a taller (and better looking) antenna now! and i painted the antenna base to match my car (it was gray and fading)
UPDATE
there was a part that fell off the antenna mast before i put it on. re-installed everything and it works great now... still loud though
Old Mar 31, 2009 | 05:51 PM
jayturk99's Avatar
Default Antenna mast
I replaced mine with one I picked up on ebay. It was an easy fix. The motor has to be working for the replacement to solve your problems. I ran into the same problem of trying to get the thing out, what I did was take the unit off, opened it up, but left the power leads connected. I turned the radio off and as the motor pulls the mast down I ran to the back and manually pulled it out. Had to reverse the process to get it in. Hope this helps.
Old Mar 31, 2009 | 06:13 PM
rtdodger's Avatar
So, what magic did you use to get the mast out? I'm currently struggling with mine.
Old Mar 31, 2009 | 07:43 PM
Yank it hard after the nut is off.
Old Mar 31, 2009 | 07:58 PM
Originally Posted by tech
yank it hard after the nut is off.
lol!!!
Old Apr 2, 2009 | 10:06 PM
BlazeS70's Avatar
I went to the junkyard, picked a power antenna off an 850, and it works better than the old one did.
Old Apr 5, 2009 | 10:20 PM
Default Power Antenna Switch...
I would like to switch my power antenna. I think they last longer if they are not going up and down every time you put the key near the car.
My 960 has a switch that I can use to keep it down when I'm using my MP3 or playing a cd. So, I picked up a switch while at our somewhat local Volvo grave yard. Does anyone know what color the wire is that comes from the radio? I plan to put the switch in the power line, that should keep the antenna down. I also need to put it down to go through our NEW car wash.
Old Apr 5, 2009 | 11:14 PM
http://au.geocities.com/OZBRICK850/antenna-switch.html
this site has some instructions and pictures. good luck with installing that! i was considering it but i don't have time for that kind of stuff really. if i tried i am sure i would break something else and cost myself $300 or something insane like that.
Old Apr 6, 2009 | 07:07 AM
Default Antenna Switch...
Thanks for the info. I think I will go that route instead of the way I was going to do it, with a switch that would not have had the light in it (I think I have an extra fog light switch). Hard to believe that Volvo would sell this for under $40.
Old Apr 6, 2009 | 07:31 AM
rg500's Avatar
I just bought one of these replacement masts on Ebay -- haven't installed it yet.
Is it a pain or something?
Electronics is my business so hopefully it won't be problematic -- I'll post my results when I get around to looking at it.
Old Apr 6, 2009 | 09:06 PM
it isn't as bad as i made it. you have to yank really hard when its all the way up to get the metal sleeve out. if the plastic chain is broken, you have to open the motor to get the broken pieces out
Old Apr 7, 2009 | 10:47 AM
I checked out the link and it is exactly what I want to do. However, the switch at our local stealership wants $69 for the kit. I'm going to check Borton Volvo online.
alecw81
Jan 7, 2009 05:22 PM
PE**2
Mar 17, 2008 05:30 PM
Crispin
Oct 12, 2007 09:28 PM
fast850r
Jul 27, 2007 09:32 AM
postdoc99
Feb 15, 2006 08:42 PM
