Power for my boost gauge
Old Sep 17, 2011 | 07:21 PM
xxblindxx's Avatar
Default Power for my boost gauge
Trying to figure out what wires at which on my lights, need the power, running, and the on/off wires.. Cant find a diagram anywhere..
If someone knows or can point me in the correct direction that would be great!!
Old Sep 18, 2011 | 09:02 PM
You can alway jump wires to figure it out. I think the black is usually the 12V wire. The pink is likely the ground. The switch is likely wired for fogs, even if they are not installed. Then you have a wire going to the ignition.
I'm looking at a diagram and it looks like the following:
GRN/RED = Headlights System
WHT = Interior Lights (Rheostat)
RED/BLK = Hot At All Times (fuse c8)
BLU/YEL = Hot W/ Overlaod Relay (fuse c26)
YEL = May be to the rear fogs.
WHT/BLK = Rheostat
PINK = Ground
I'm not real good at reading wire diagrams but this is what I can tell.
Old Sep 18, 2011 | 09:19 PM
BTW, why does your thread say "power for my boost gauge"?
Old Sep 19, 2011 | 05:47 PM
pitrow's Avatar
'cause he's trying to figure out where to get power for his boost gauge.
Old Sep 19, 2011 | 06:42 PM
xxblindxx's Avatar
Sorry, should have stated what i was trying to accomplish in my post as well. I'm trying to figure out the best/correct way to get power for my boost gauge (back light). I think going from the headlight control is the best way, just trying to figure out the correct use of each wire coming from it.
Thanks!
Old Sep 19, 2011 | 07:26 PM
I usually tap into one of my switch lights.
Old Sep 25, 2011 | 07:17 PM
xxblindxx's Avatar
http://www.glowshift.com/instruction...oost-Gauge.pdf
That is what i'm trying to hook up
Old May 14, 2020 | 01:21 AM
Davidfedorchak's Avatar
Originally Posted by xxblindxx
did you end up having any luck getting power to your gauge?
Old May 14, 2020 | 08:27 AM
Psaboic's Avatar
Doubt you will get an answer, as the last post was 9 years ago.....
559s40
Jul 13, 2012 10:50 PM
ibified
May 26, 2011 01:03 AM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
