radiator fan wont turn on
Old Mar 6, 2011 | 01:07 PM
yagton's Avatar
Default radiator fan wont turn on
One night I turned off my car and the fan continued to run. I then turned my car back on and the check engine light came on (but I didnt have a tester so I don't know the code). Turned the car off again. Let the fan run for about 5mins before then I unhooked the battery so it wouldn't kill my car.
The next morning I hooked the battery back up and then fan didn't run and no check engine light so I thought I was fine. But the fan wont run at all now and I'm getting no check engine light.
I checked my connection and they're all in. I also checked all of the fuses.
Update: New relay didn't work and emission testing said their computer wont read when hooked to my car.
Old Mar 6, 2011 | 02:35 PM
v70man's Avatar
Default v70man
well.... it sounds as if there is an issue with the relays on the cooling fan... i had relays go on my V70 they were driving the fan crazy! first when i shut down the engine the fan ran on ...ok. but didn't stop! then in traffic the next day the dam engine started to overheat! so i had the relays changed and the problem dissapeared
Old Mar 7, 2011 | 03:59 PM
yagton's Avatar
new relay didn't work.
ingydrummer
Feb 28, 2020 03:33 PM
mikev40
Sep 28, 2014 08:01 PM
dejr
Aug 21, 2012 07:15 PM
moros323
Jul 26, 2008 09:00 AM
elouadj
Jun 25, 2008 07:00 PM
