radio code
Old Oct 25, 2007 | 06:40 PM
robretpd's Avatar
Default radio code
I had to disconect the battery. The radio now says code on it. I beleive I have the 4 digit code, how do I imput it? The car is a 1999 S70 awd...
Old Oct 25, 2007 | 07:47 PM
Default RE: radio code
You need to get it from the Dealer.
Old Oct 25, 2007 | 08:25 PM
robretpd's Avatar
the dealer gave me the code...how do i imput it?
Old Oct 25, 2007 | 09:44 PM
samadkins29's Avatar
using the cd numbers:
The six buttons on the bottom right of the radio
Old Oct 26, 2007 | 01:19 PM
robretpd's Avatar
Thanks, the dealer made a mistake withthe numbers and now it says off. I looked in the manual and it apaprently is locked. The book said to leave the car off for 2-3 hours nad it will reset to say code. That did no thappen, any thoughts on how to get it bck to say code?
Thanks again.
Old Oct 26, 2007 | 01:56 PM
billofdurham's Avatar
Did you leave the ignition set at Position 1 and the unit left on?
This is from the owner's manual:
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period: [*]the battery must be connected[*]the ignition key must be turned to position I[*]the unit must be turned on
Old Oct 26, 2007 | 04:22 PM
robretpd's Avatar
Nope I did not, I just went out to turn the ignition to 1 position. When I put in the codes, after i did it it just stayed on the numbers I punched in, I never got the "rpt" thing. If it is done correctly, should it autamaticaly start working?
Old Oct 26, 2007 | 06:03 PM
Flip's Avatar
When you input the wrong code it goes to off until about 2 hours, but you need to leave the key in position 1 during that time. So I hope you have a garage where you can leave it sit with the keys.
Old Oct 26, 2007 | 08:17 PM
robretpd's Avatar
thanks, I got the code back. Unfortunatly I put in the code that was given to me by the dealer and all I got was EEEE. So after 2 tries I stopped. I will call the dealer tomorow to make sure I got the right code
Old Oct 26, 2007 | 08:39 PM
You will have to give them the radio model # and serial number to make sure they give you the proper one.
Old Oct 26, 2007 | 11:44 PM
Volvocars's Avatar
Pull out the radio and see if a different-4 digit-number is written -not printed on the tag-on the top. That may be the number you need.
Old Oct 27, 2007 | 07:30 AM
robretpd's Avatar
Ok I remembered that I had a problem with the radio and speakers awhile back. I called the dealer again and got one of the service reps I know. He looked up te history and found a radio repair and new code. I put it in and it works...Thanks for all the help.
cbgav
Sep 10, 2007 05:25 PM
jayb
Aug 27, 2004 09:29 PM
Cyrusjj
Nov 15, 2003 06:33 PM
