Rear door not locking
Old Jan 2, 2025 | 03:20 AM
Matt4how's Avatar
Default Rear door not locking
Hi all
My drivers rear door is not currently locking. All the other doors lock fine when using the car fob.
I can see it try to go down and goes most of the way when locked but seems to stop and not go as far as it should. Any ideas on what this might be and how to fix it?
thank you in advance.
Old May 15, 2025 | 08:49 AM
admasters's Avatar
Default check RobertDIY
First check to make sure the connecting rod is not binding, the look up RobertDIY. He did a video about the "thermal switch" inside the powerlock mechanism. That might be your problem
Originally Posted by Matt4how
Hi all
Old Jul 25, 2025 | 04:58 AM
dhsyu's Avatar
If you watched the initial video on youtube the sticking door lock, you’ll see that straight lubrication of the mechanism did the trick.
192.168.100.1 192.168.1.1
jpjonas
Nov 10, 2014 02:06 PM
teller
2001-2013 model year V70
May 22, 2013 12:51 PM
Hokiefanatic93
May 12, 2011 02:56 PM
hhiii
Oct 19, 2009 10:45 PM
Cornfed
Nov 16, 2006 12:46 PM
