Replacing AWD S70 transmission.
Old Aug 22, 2012 | 12:43 PM
elcs70's Avatar
Default Replacing AWD S70 transmission.
Hey guys, I have searched, including the DIY stickies, and I cant find a good write up about replacing the transmission, can somebody point me in the right direction? Id greatly appreciate it.
Old Aug 23, 2012 | 05:18 AM
Lifesgoodhere's Avatar
s70 AWD has the EXACT same underpinnings as that of the V70.
search in the V70 area, and ignore the body style. takes about 8 hours in and out on a lift.
Old Aug 24, 2012 | 07:17 PM
elcs70's Avatar
Thank you, lifesgoodhere. I have also printed off the walkthrough from VADIS, so i feel comfortable doing the replacement. I firmly believe that my transmission failed due to my bad viscous coupling. So, here is my plan: I am going to purchase a used FWD transmission and remove my angle gear and driveshaft so that I will have a FWD vehicle now. Does anyone foresee any issues with this? Any help would be appreciated.
Old Aug 25, 2012 | 12:23 PM
mmmm I would just disconnect/remove the driveshaft. What you are going to try doing is making it front wheel drive. Ok, would work fine as long as the transmission is the same (aw50-42 I think that is the 2wd one) im thinking the AWD has a different tranny in it. Also you would have to buy a new passenger side axle.
Old Aug 25, 2012 | 06:27 PM
elcs70's Avatar
well, today, i pulled the drive shaft off, and have done all but the final unbolting of the transmission. Waiting to do that until new used transmission arrives. I ordered a used AWD transmission with 90k on it. Since the AWD system is purely mechanical in this car, i feel that it will be no problem have an AWD tranny not connected to any drive shaft (this is a cheapest fix type of deal, mind you).
Old Aug 26, 2012 | 05:31 PM
yes, but when you disconnect the driveshaft, the angle gear spins, but with no load of the rear part of the AWD system. Toque flows straight through, like a bearing.
What I mean, you could (have) removed the angle gear, bought a right side axleshaft (CV shaft) and not needed to replace the entire tranny, if the tranny is the AW50-42 (2wd tranny I think. Might have been used on AWD models as well, not sure, never paid that much attention to it.)
Old Aug 26, 2012 | 08:28 PM
elcs70's Avatar
the transmission i ordered is 50-42LE. Which may indeed be the FWD tranny. I believe that the front axles will work just the same. If it is the FWD tranny i will have no need for the angle gear, and if i remove the rear axles, then they will spin freely. problem solved. will let you know if it is the FWD or AWD tranny. I need to do some more reading on the part numbers of the trannys
Old Sep 8, 2012 | 08:47 PM
elcs70's Avatar
UPDATE: used FWD transmission installed. Had to get new passenger side front drive axle. transmission control module has tranny in limp mode. Have used TCM on the way ($20 off ebay is cheaper than getting the original flashed at the stealership). BTW, i pulled to rear axles in the hope of avoiding problems dragging the rear differential; well, this causes the anti lock breaks to cease working, so i have to put those back on in the morning. should be good to go when the new control module comes in.
mbsjshad
Apr 5, 2014 08:04 PM
mbsjshad
Oct 16, 2013 09:12 AM
awdMN
Nov 28, 2010 09:08 PM
trans am
Apr 16, 2009 09:17 PM
lavy
Nov 18, 2005 09:51 PM
