rough idle, not MAF sensor. 1999 S70 GLT
Old Nov 28, 2011 | 04:54 PM
ohmartha's Avatar
Default rough idle, not MAF sensor. 1999 S70 GLT
Hi all,
I've researched this issue and found out it could be a dirty MAF sensor, so I disconnected the MAF sensor and started the car but the idle remained rough. I've read that cleaning the throttle body helps so I got CRC throttle body and air intake cleaner but on the bottle it says not to use on turbocharged engines? And I have no idea where the throttle body on the S70 GLT is anyway...
What else could it be?
Old Nov 28, 2011 | 08:20 PM
Do you have a CEL?
Old Nov 28, 2011 | 09:31 PM
ohmartha's Avatar
Originally Posted by rspi
Do you have a CEL?
Nope. But speaking of, the lightbulb light turns on whenever the brake pedal is stepped on
Old Nov 28, 2011 | 10:13 PM
That means you have a brake light bulb out.
You have a '99 so you may have a bad throttle control. They go out a lot in those cars. If you do not have a cel, you are likely not missing.
Old Nov 29, 2011 | 02:38 AM
ohmartha's Avatar
What do you mean not missing?
And thank you for the brake light answer, very helpful
Old Nov 29, 2011 | 09:16 AM
Missing means that one of the cylinders in your motor is not firing. That is the most common cause of rough idling. You have 5 cylinders and if 1 of them is not firing, it will cause a rough idle. How many miles does the car have on it?
Old Nov 29, 2011 | 03:12 PM
ohmartha's Avatar
Approximately 120k.
I might also add that the car dies every now and then while driving, usually during stops.
Old Nov 29, 2011 | 06:42 PM
https://volvoforums.com/forum/volvo-...-stalls-55928/
In that case, try this first. Fuel pump relay.
johnmal85
Jul 23, 2014 07:36 PM
aleksey17
Dec 29, 2011 12:54 AM
johnhon
Oct 3, 2010 03:04 PM
RooTS/S70
Sep 20, 2009 08:15 AM
StevenA86
Jun 8, 2009 06:50 PM
