RPMs fluctuate when in reverse and holding brake
Old Feb 19, 2010 | 02:06 PM
thedigid's Avatar
Default RPMs fluctuate when in reverse and holding brake
I have this problem that only appears maybe 1 out of 10 times when I drive my car. When it happens its something like this. I turn the car on the idle is rough the tach was bouncing between 500-1500 rpms almost as if the car is going to stall. If I wait for 30-60 seconds it will sort it self out and then idle smoothly at 1000rpm. So today I didn't wait the 30-60 seconds and popped it into reverse which I noticed to be a bit of a jerk and then I started to reverse without pushing on the gas. However the tach was still bouncing between 500-1500rpm and every time it hit 1500rpm its like the car was pushing on the throttle and making me reverse even faster. SO I hit the brake and every time it hit 1500rpm the only thing keeping the car from accelerating backwards quickly was my foot on the brake. So I pulled out started going forward for about 15 seconds pulled over and put the car in park and the idle was fine at 1000rpm. Not sure where to go from here.
Old Feb 19, 2010 | 09:29 PM
What year is it?
Old Feb 20, 2010 | 07:43 AM
thedigid's Avatar
Its a 99 GLT. And the check engine light hasn't come on.
Old Feb 20, 2010 | 05:41 PM
I would try cleaning the throttle body first.
vpatrol
Jul 7, 2009 06:26 PM
silkhope
Jul 4, 2009 12:32 AM
bidonox
Apr 8, 2009 07:38 PM
STREETFIGHTER50
Mar 18, 2009 08:46 PM
heybuddy
Apr 18, 2007 12:58 PM
