RR window goes down but not up...motor & switch good though?
Alright, I did a search but could not really locate anything like what I have going on here. The car is a 1999 S70 non-turbo. I have a RR window that will go down but not up from both the master switch and the RR switch itself. The RR switch is new from the dealer as I tried replacing that first after it seemed like that was the issue. If I put power to the motor one way and the other the motor will run the window up and down. But when it is hooked up through the wiring harness of the car it will only go down. At a loss here as to what it can be. Is it something in the Master Switch on the driver door...like a relay internally or something that would cause the window not to go one way but the other? Is there a module or control unit somewhere that could be the issue on this car? Thanks for any help.
The wiring seems fine as the problem only occurs when the circuit is completed through the master switch. If you run power through the wiring directly to the motor it goes in either direction. I was thinking master switch, but I didn't know if there was a relay or control unit somewhere that could also cause this before I drop $100 on a new master switch.
86volvoguy
04-20-2017 10:50 PM
Doormat
03-28-2012 10:03 PM
