S70 Cooling Fan
Old Jan 3, 2010 | 06:37 PM
Reap3r89's Avatar
Default S70 Cooling Fan
Hey guys got a little bit of a problem with my 98 non turbo s70. Cant put my finger on it but as I'm driving at days when its really cold out my check engine light turns on followed by my cooling fan. After that my heat just dies and i get cold air blowing. When i get to where ever I'm going I pop my hood and pull out the fuse for the fan. It turns off and so does my check engine sign. So if you guys have any clue to what is going on please let me know. Thanks
Old Jan 3, 2010 | 10:52 PM
Mtl_Volvo_Man's Avatar
Check the coolant level
Also coolant temperature sensor
also fan resistor or relay going bad
good luck
Old Jan 4, 2010 | 04:27 PM
s70_t5_1999's Avatar
my car was doing the same thing (w/o the CEL) but it fixed itself on the way to have the dealer check it out. of course.
Old Jan 4, 2010 | 11:05 PM
Carrots's Avatar
Thermostat and temp sensor, That's what it sounds like to me.
Old Jan 5, 2010 | 12:16 PM
Reap3r89's Avatar
Might be a stupid question but where is the temperature sensor? I know where the thermostat is but not the sensor
Old Jan 7, 2010 | 07:04 PM
akem21's Avatar
I had the same problem with my fan on my 1999 S70. I unplugged it, the CEL went out eventually, replaced the thermostat, plugged the fan back in and haven't had problems since.
I believe the temperature sensor is located in the thermostat housing. You'll see the wires under the hose.
VancetheVolvo
Feb 15, 2015 08:01 PM
uwphoto48
Dec 23, 2012 02:51 PM
norasaint
Sep 20, 2012 12:53 AM
jets555
Mar 26, 2011 01:02 AM
elouadj
Jun 25, 2008 07:00 PM
