S70 Exhaust Cam Gear Removed
Old Sep 1, 2011 | 12:36 AM
Shelltracks's Avatar
Default S70 Exhaust Cam Gear Removed
Hello, I have joined this forum as it is very resourceful and everyone is very knowledegable about the Volvo! So I have a 2000 S70 GLT SE 2.4 Turbo that I am working on and it has and oil leak out of the intake camshaft seal and badly blows out a thick stinky white smoke while running. I cleaned the PCV system and am replacing the camshaft seals. I had loosened the rear camshaft sprocket only to find out that it's not on any kind of grooves or teeth and now I need to figure out where it belongs so I can out it back together. The rear exhaust sprocket does not look like the front intakes cam sprocket with just three bolts. The rear exhaust cam sprocket has a Torx cap over another Torx bolt that holds it to the cam. Any ideas and input would be very helpful and apppreciated Thank you
Reagan
North East
Apr 6, 2012 02:28 PM
ekugler7@msn.com
Jun 21, 2010 04:34 PM
Crate45
Jul 7, 2008 10:34 PM
shrike
Feb 22, 2008 05:29 PM
Carbuff
May 19, 2005 04:44 PM
