S70 GLT Transmission issue????
Old Jun 15, 2012 | 11:05 PM
gterderek's Avatar
Default S70 GLT Transmission issue????
Have a 1999 S70 GLT. Only 55000miles.
I am not really a car person and english is not my mother language so I will try to explain my situation the best I can.
I was driving in a local road yesterday, the yellow arrow light turned on(not blinking) suddenly. I dont feel anything abnormal on my car. Everything looked the same as before. When I was stopped at the traffic signal, I tried to Switch from D to P and then switch it back to D to see if the light would go away. The yellow arrow light was still there, what's more, check engine light was turned on. Today, when I restarted my car, the yellow arrow light goes away, but the check engine light is still there. I got the code from autozone. They are p0442 which corresponds to (defective or loose fuel cap/evap canister or hose cracked-not connected/purge or vent solenoid defective/vacuum leak at engine) and P1113 (failed intake resonance valve/open or short circuit condition).
Do you have any idea about what's the problem of my car? Do I need to change the transmission fluid or replace the PNP switch? Or maybe I am going to lose my car because the cost of fixing transmission is too expensive.
Thank you for any help.
Old Jun 16, 2012 | 06:06 AM
Not sure about the problem but if the arrow wasn't flashing, the problem is likely minor. Deal with your issue and don't worry to much.
Old Jun 16, 2012 | 11:18 AM
gterderek's Avatar
Thank you very much. Except for bring the car to dealer, do you think I can do sth which is helpful for me car?
Old Jun 16, 2012 | 11:45 AM
If you fixed the problems with the code I don't think you need the dealer. If you can not solve the problems, the dealer will likely be best.
Old Jun 17, 2012 | 11:56 AM
gterderek's Avatar
Thank you. I try to replace j hose first.
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
johnmal85
Jul 23, 2014 07:36 PM
uwphoto48
Dec 23, 2012 02:51 PM
theoldsalt
Aug 20, 2009 08:07 PM
