S70 idling at 700 rpm w/ slight shake
Old May 29, 2011 | 06:45 AM
VTBricked's Avatar
Default S70 idling at 700 rpm w/ slight shake
The car runs great at speed and when accelerating. However, at idle, it shakes slightly. I just replaced the upper and front-right mounts, but at idle (700 rpm) it shakes. Any ideas?
Old May 29, 2011 | 12:20 PM
RPM's is a little low. Usually a shake is missing. Have you scanned for codes? How old are the wires?
Old May 29, 2011 | 02:59 PM
tony1963's Avatar
Behaves like a vacuum leak.
Old May 30, 2011 | 05:03 PM
VTBricked's Avatar
Thanks guys. I'll check both. But the CEL is not on.
The wires are probably very old. The PO was Nancy Neglectful. The heater core was SO bad the carpets were like a swamp, and the windshield IMMEDIATELY fogged when the defroster was on - it was more like a mister! She neglected the driver's door latch that it failed in a closed position - a delight to remedy! And I could go on.
Albe_Darned
Jul 20, 2013 01:51 AM
SeanF
Jan 7, 2012 10:17 AM
xakkaxxx
Aug 24, 2010 04:05 PM
mooses9
Sep 7, 2009 11:21 PM
clintw
Jan 22, 2008 08:05 AM
