s70 power adders!
Old Jun 4, 2008 | 07:01 PM
S70Evil's Avatar
Default s70 power adders!
so i just baughtmy buddies dad 98 s70 T5 and im wondering what you volvo gear heads out there are doing to wake up these allready quick cars! nothing to elaborite now, im thinking exhauste, intake maybe boost controler, bov?..anyways where could i source out thses kinds of parts and what would you recommend for it as far as speed improvements go
Old Jun 4, 2008 | 07:20 PM
S70driver's Avatar
Default RE: s70 power adders!
1. You need to search.
2. You need to complete STAGE ZERO.
Full stage 0 list:
Plugs
cap/rotor
oil/transflush
filter (oil)
hoses (the little vac lines)
samco hose kit or Stylin Motors Inc. hose kit (Turbo Models ONLY)
02 sensors
fuel pumps
clean injectors
clean IC/IC plumbing (Turbo Models ONLY)
Air filter
plug wires
Also get a boost gauge that can read 25 In Hg/25 PSI.
3. What is your budget?
4. What is your Hp goal?
*The most popular things to do are as follows...
A. Intake
B. Downpipe
C. Catback
D. ECU upgrade
IMO I don't recommend using a Manual Boost Controller (MBC). I suggest you raise the boost via an ECU upgrade.
Again I suggest you search, I have created a wonderful thread that has many different sites listed.
https://volvoforums.com/m_38606/tm.htm
-IPD USA
-EuroSportTuning (EST)
-Viva Performance
These are the three companies I recommend.
DanSC
Jul 5, 2013 08:34 AM
T K
Mar 22, 2011 03:32 PM
mark_disfree
Dec 19, 2008 01:10 AM
elderzap
Nov 7, 2007 04:58 PM
m_schiff83
Aug 10, 2007 05:06 PM
