S70 problem
Old Apr 7, 2018 | 06:25 PM
Benji Buddy's Avatar
Default S70 problem
Help! I'll keep this as short as possible. 1998 S70. Water pump locked up and timing belt broke. Bent valves, of course. Bought a Chilton Volvo repair manual. Followed the steps faithfully for pulling the head. In the steps it said to remove timing belt sprockets, before removal of cams. So I did. IT DID NOT SAY TO MARK THEM FIRST! 3 bolts hold them on. I assumed since it didn't say to mark them first, they only went back together one way. WRONG! They'll go on 3 ways! How do I fix this?? Other than a random (?) mark on the cam where the sprocket bolts on, there's nothing. I've got the head back in, but can't go any farther. Again, HELP!
Old Apr 7, 2018 | 07:57 PM
see if there are markings on the other end (non-gear side)
Old Apr 7, 2018 | 09:12 PM
No no markings on the other end. Although one has the rotor for the distributor on the other end.
Old Apr 7, 2018 | 11:22 PM
firebirdparts's Avatar
Those engines were timed on the other end, and the crank gets put in position using a little doo-dad inserted in a hole behind the starter. If you can find the timing mark on the crank, you can skip the doodad, but I think you are stuck using the rear of the cams for timing at this point. Look for tools to hold the cams, either factory style or somebody's home-brew design.
I don't recommend anybody look in a chiltons for any reason, but I suppose in this case if you'd have looked in the factory shop manual you might have come to the same spot.
Old Apr 8, 2018 | 02:42 PM
tony1963's Avatar
You need to buy the tool to hold the cams in place. That is the only way to time the engine.
valvok
Aug 10, 2017 06:29 PM
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
rainman14624
Oct 4, 2010 11:49 AM
kingd
Nov 20, 2009 12:37 AM
haubica14
Sep 27, 2008 08:17 AM
