S70 Slow starts
Old Dec 6, 2005 | 01:08 PM
OME's Avatar
OME
Default S70 Slow starts
What are the signs of a bad clucth. My wife's 2000 S70 5 speed manual transmission having problems starting. The clutch has to be push to the floor several times before the car will start.
Old Dec 6, 2005 | 08:44 PM
Default RE: S70 Slow starts
Under the dash by the pedal there should be a switch that might need adjustment.
Does it not turn over?
Does it turn over and not start?
Old Dec 8, 2005 | 05:31 PM
OME's Avatar
OME
Thanks
The clutch has to be firmly press to the floor several times before the car starts. THe switch is located under the dash by which pedal? How do you adjust the switch?
Old Dec 9, 2005 | 12:11 AM
Sorry it is by the clutch pedal. The switch should slide in and out of the mounting to adjust.
Old Dec 11, 2005 | 11:50 AM
OME's Avatar
OME
Thanks , I'll give it a try.
Gardenhands
Jun 6, 2012 08:56 PM
KatieK
Nov 11, 2010 10:29 PM
eagles9989
Sep 3, 2009 06:49 PM
par5
Dec 9, 2008 08:55 AM
pizzler84
Feb 13, 2008 10:02 PM
