Secondary Air Injection System Problem
Old Feb 18, 2006 | 08:08 PM
Air Defender's Avatar
Default Secondary Air Injection System Problem
I keep getting a check engine light. The code is P0410 Secondary Air Injection System Malfunction. Here is some background. I replaced my Secondary Air Pump 6 months ago when it started making loud noises. Now a few weeks ago I get the P0410 code, I replaced the relay and cleared out the code. Now the code comes back after several hundred miles. Any thoughts on this problem? Should I replace the solenoid?
Old Feb 18, 2006 | 10:14 PM
Default RE: Secondary Air Injection System Problem
Have you inspected the Valve at the back top of the engine?
Remove the Valve and put vaccum to it and make sure it opens and closes. They will also get clogged as well.
Another thing to is the Vaccum elbow will break and then not open the valve sometimes.
Old Jul 21, 2011 | 12:23 AM
pburnhamb's Avatar
I am having the same problem with my 1998 v70 non turbo. i cant opperate this search too well. it keeps telling me there are tooo many posts about code 410 or "air" in secondary air system. im new to this place and know the info is here somewhere i just cant access it. i would like to check my valve and the pump. would you please explain to me where they are located. thank you. -patrick-
danborisuk
Jan 1, 2012 09:58 PM
I8ASaleen
Oct 4, 2010 11:53 PM
bigdummy
Aug 1, 2009 03:18 PM
tom1568
Dec 21, 2005 09:36 PM
jrw
Nov 19, 2005 09:13 PM
