servce light on dash
Old Aug 31, 2013 | 04:46 AM
jazsam's Avatar
Default servce light on dash
hi can the service light on the dash be reset after a service has been done by a non volvo engineer on a 1998 volvos 70?
Old Aug 31, 2013 | 11:01 AM
kwatt's Avatar
I'm interested myself. I've seen some instructions from the web
-Put the key into the ignition and turn it to position "I."
-Press the trip odometer button in and hold it. Turn the ignition key to position "II."
-Wait about 5 seconds until the service engine light begins to blink. After the 4th blink, turn the ignition key back to position "I."
-Release the button and start the engine. The light should have turned off. If not, repeat steps 1 through 4 again.
I've tried this multiple times but the light does not reset. It just comes on when the engine starts and goes off after like 2-3 minutes.
Old Aug 31, 2013 | 11:39 AM
Yes, if they (or you) have a special tool.
Old Aug 31, 2013 | 05:16 PM
ES6T's Avatar
That procedure is for 99 and later. rspi is right, you need the special tool.
Old Sep 2, 2013 | 03:17 PM
kwatt's Avatar
Turns out you can reset the service light with the trip reset. I changed the oil and followed the procedure; Servicde light is off.
-Hold in the reset button
-Turn the ignition to the RUN position
-When it starts blinking, release the trip button after the 3rd, but before the 4th blink
-Ignition off
Start the engine, Service Light" will be off.
lister99
Dec 28, 2012 10:46 PM
trs80
Jun 25, 2011 02:05 PM
tr_car_nut
Jan 19, 2008 09:37 AM
Erock198
Aug 3, 2004 02:09 PM
