Squeaking from wood dash around climate\radio
Old May 2, 2014 | 06:59 AM
RA082324's Avatar
Banned
Default Squeaking from wood dash around climate\radio
Hi all,
I've read many a post about the infamous dash squeak/rattle...but I'm fairly certain mine is different...it seems to change with humidity/temperature and if I put my hand firmly (and press) on the climate control center/wood dash around it, I can get the sound to stop. How do I go about removing the piece in question to take a look and possibly fix? I do need a new wood dash center anyway (around radio/climate) as there are chips/cracks in it.
Old May 14, 2014 | 08:40 AM
That stuff is secured from behind. You will have to pull the dash out.
As for the dash mounts being bad, that is very likely your problem. There are 4 mounts, if a center mount is bad, and you push on the trunk hard enough, it may stop the dash mount squeek.
Old May 15, 2014 | 06:03 AM
RA082324's Avatar
Banned
With the car sitting I'm able to push on the climate control lightly and get massive squeak. I watched the videos of said dash mount tabs broken...mine sounds very different. Not saying you aren't probably right, but I'd like to try the easier stuff first if possible. The climate control unit comes out by pushing it out from behind, right?
Old May 19, 2014 | 06:55 AM
Is it ECC or MCC? ECC units push out from behind. MCC units have a screw behind the *****.
You can pull the climate control unit and the radio. A guy told me that the x70 cars have screws behind that molding and those trim pieces can be replaced. Maybe you can reach the screws with those controls pulled. Post your results, squeeking sucks.
Old May 21, 2014 | 12:04 PM
RA082324's Avatar
Banned
ECC I believe, thanks...will try this out this weekend and keep you posted. Squeaking does suck, but thankfully I have a great sound system lol
Ian Mclean
Jul 20, 2013 01:03 PM
mshack
Sep 20, 2009 02:13 PM
ciao-rich
Jun 13, 2008 05:01 PM
TDolce
Jun 29, 2007 08:01 AM
Bummer
Jun 22, 2005 05:42 PM
