SRS warning light and no horn
Old Aug 23, 2008 | 09:54 PM
bilbo925's Avatar
Default SRS warning light and no horn
I just completed a dash repair on my 98 S70. Unfortunately, while I was waiting for my father-in-law to bring me some stuff I decided to also work on the master window switch. To test my handy work I reconnected the battery while both air bags were laying in my shop floor. Now my horn won't work and the SRS light won't go off. My cheap code reader doesn't read SRS codes. Can any independent mechanic with a "good" code reader reset the light? And what about the horn? Anybody got any clues?
Old Aug 23, 2008 | 10:08 PM
Default RE: SRS warning light and no horn
Did you lock the contact reel before removing the steering wheel? If so did you tighten the R/S of the screws for the air bag first?
A shop with a GOOD reader should be able to read and clear the SRS.
Old Aug 23, 2008 | 11:05 PM
bilbo925's Avatar
I found the horn problem... left a wire unplugged (duh!). As for SRS, yes I tightened the right side first. I also removed the wheel again and inspected the Contact reel. Its a little brittle at the mount holes but otherwise looks okay. I gently reinstalled it and the wheel and air bag. Everything looks good, just cant get the SRS warning light to go out. Is it because I connected the battery while the airbags were disconnected?
Old Aug 23, 2008 | 11:28 PM
Yes it is you will need to get it reset.
Old Aug 23, 2008 | 11:36 PM
bilbo925's Avatar
Thanks for your help. I used your post as my instructions for the dash repair. That part of todays work went very smooth. Now all I have to do is find someone in rural west tennessee with a code reader. Once again thanks and God bless.
Old Aug 24, 2008 | 07:50 AM
Glad the post was useful. Hope you find someone that can clear it.
Old Aug 28, 2010 | 05:27 PM
Yuk!!! The SRS light in our S70 came on today. The manual says that I need to get it to the stealer to have them check the system because something is wrong.
Anyone had any experience with this problem and the cost to get it fixed???
volvo_s70
Mar 9, 2013 11:54 AM
Sparky4688
Sep 26, 2009 06:22 AM
VOLVO15
Apr 20, 2009 08:09 PM
Ron Earp
Jul 8, 2007 12:30 PM
fopdod
Jan 18, 2005 06:45 PM
