trouble starting
Old Jun 17, 2006 | 05:35 PM
veso_ht's Avatar
Default trouble starting
hi everyone,
i have a 2000 s70se. Sometimes, it has a hard time starting. It will start and then die imediatley. I think it might be the alarm since after it dies, the red light on the dash starts blinking. the only thing that seems to help is if i turn off the daytime running lights, the ac & radio off & close the doors so the lights are off. sometimes if that dosent work i have to lock & unlock the car again. sometimes it will do it once, sometimes 20 in a row... could it be the immobilizer? i got the letter from volvo about the throttle body, could it be related??
any help/opinions would be great!
thanks, veso
Old Jun 17, 2006 | 05:41 PM
Default RE: trouble starting
Possibly the ETM (Throttle body) but I would look more towards the Immoblizer/Key.
Do you have another key you can try using for a little while to see if it stops?
Old Jun 17, 2006 | 07:39 PM
veso_ht's Avatar
no, i only have one key. if i get one cut from the dealer do you think it might work or is the whole system that needs to be replaced?
Old Jun 17, 2006 | 08:12 PM
It is hard to say.
The key will run you Like $100.00 or more to get.
Another thing it could be is the Antenna ring for the Immoblizer.(Light around the ignition switch.
When it happens again try taking the key out and turn it 180 Degrees and try again. The chip in the Key is placed more to one side. Sometimes it will not read when it is on one side.
You might also want to think about replacing the Antenna ring(Light around Ignition switch)
This is usually the Order the Dealer will try.
Antenna ring
New key
Immoblizer with 3 new keys
Old Jun 18, 2006 | 05:07 PM
veso_ht's Avatar
thanks, i'll try it and let you know. i've had the car for two years & it's becoming more of a problem. my aunt has the same but a 99 and her's started the same thing as well.
veso
Old Jun 20, 2006 | 02:28 AM
mo t5's Avatar
Please post if you fixed it or eliminated one of the steps, my v70 is kinda doing the same thing.
Old Jul 2, 2006 | 02:21 PM
veso_ht's Avatar
it's the antenna. everytime it dosent' start, just flip the key & it works perfect! haven't had time to replace the antenna yet, but it seems to be the problem.
Thanks, Veso
snoboarder_mike
Jun 15, 2011 07:39 PM
foker500
Aug 3, 2007 09:53 AM
GRHMB
Jan 25, 2007 08:30 PM
sdat1333
Dec 23, 2006 04:16 PM
sagi122
Oct 8, 2006 10:54 AM
