Volvo S70 98 A/C clutch not engaging
Old Jun 7, 2009 | 08:02 PM
mkangrga's Avatar
Default Volvo S70 98 A/C clutch not engaging
Good afternoon,
I have a 1998 Volvo S70 and an A/C problem. Namely, there is no cold air blowing whatsover when A/C is on, and it appears that the A/C clutch never gets engaged (after toggling a/c, waiting, etc.) I checked all the connections and they seem to be proper. Before this, although it may not present relevant results, I checked the pressure on the low-pressure end and it read 80 PSI after a few minutes of running (although it seems like such a high reading may be due to the compressor/clutch not engaging). Would you please kindly advise as to what the problem with the clutch may be and if this would require a replacement of the compressor itself (and how much the costs normally run), or point me to a thread that touches on this issue?
Many thanks for your help!
-Marko
Old Jun 7, 2009 | 08:34 PM
Do you have power on both sides of the low pressure switch?
Are you sure you are not low on freon?
Old Jun 7, 2009 | 11:19 PM
mkangrga's Avatar
Thanks for the reply. I checked the connections only, I did not check the power... Where exactly should I check for power? I was also semi-afraid to add more R134a refrigerant, as the gauge immediately shot up to 80 PSI, whereas the general "full" level should be reading at 25-45 PSI. What would normally prevent the clutch from engaging?
Thanks again for your help.
Old Jun 8, 2009 | 04:50 AM
A bad Low pressure switch or relay could stop it from coming on.
Check for power at the low pressure switch.
Old Jun 24, 2009 | 02:40 PM
mkangrga's Avatar
Thanks for the response. I have not had the equipment to check the power at the low pressure switch, but will report back as soon as I do so. Could you please tell me how I can check if the relay is bad? Thank you.
Old Jun 25, 2009 | 07:58 PM
Swap it with another one.
corlitoa
Oct 16, 2014 03:47 PM
rockin78ta
Jul 19, 2009 03:45 PM
sblaine
Feb 9, 2009 12:03 PM
png
Dec 19, 2008 01:17 PM
