volvo S70 ignition problems
Old Jan 9, 2008 | 06:47 PM
ratfink's Avatar
Default volvo S70 ignition problems
I have a 1998 volvo S70(no turbo). Recently been feeling a click or a grind of somekind whenI turn the ignition to the start position. Yesterday I went to turn car on and nothing happened, car did not turn on or crank. All the lights in the instument panel turn on, key moves freely between positions, car is in park, but still does not even attempt to turn over. I have read the other post on ignitions but they all describe different problems than my situation can anyone help.
thanks, ratfink
Old Jan 10, 2008 | 08:08 PM
Eric J's Avatar
Default RE: volvo S70 ignition problems
https://volvoforums.com/m_89421/mpag..._/tm.htm#89502
Welcome to the forum.
This thread Sounds simular^^.
Tech, what's the answer? Thanks
Old Jan 11, 2008 | 06:25 PM
Try starting it in neutral.
Does the key still spring back like it used to?
Old Jan 11, 2008 | 10:07 PM
ratfink's Avatar
Thanks Erick J and Tech for your responses,
I tried to start the car in neutral but nothing happens, tried to jinggle the keys, even tried the "old fashion" banging on the ignition with myfist.The instrument panel comes on all the eletrical works but car does not turn over.The key does not get stuck in any positions, butyou can turn it as normal but car does not turn over.Looked at the other post and think it might be the ignition switch but hope its something more simple.
Old Jan 11, 2008 | 10:14 PM
Next would be to take a test light and put it on the small wire on the starter. I think it is blue.
Have someone turn the key to the start position and see if the light lights up.
If it lights up the starter is bad.
If it doesn't then either the Immoblizer is activating or the PNP switch is bad.
Old Jan 11, 2008 | 11:50 PM
ratfink's Avatar
thanks Tech,
will do, first thing tomorrow morning and report back.
Old Jan 12, 2008 | 10:12 PM
ratfink's Avatar
I checked the green wire on the starter and there was power when atempting to crank. So, I took the starter off and took it to auto parts to test and buy new one. When they checked it, it passed all the tests. Should I put the starter back on or should I replace. My friend that is a tech. told me it might have been stuck. Dont know what to do next.
Old Jan 12, 2008 | 11:00 PM
Eric J's Avatar
Starters can intermittantly fail, if they have a bad contact or winding in the armature. They will work with a few persuading taps.
If the solonoid on the starter is failing, it usually will click or buzz load enough to hear. A bad connection to the solinoid or battery will have simular symtoms.
Putthe starterback in. If it works, it may have been a bad connectiion to it.
If it doesn't work all the time, it's intermittant.
If it doesn't work at all, your problem most likely is somewhere else, from ignition switch to battery terminals(or weak battery)and all points in between.
Old Jan 13, 2008 | 08:25 AM
I would reinstall and see what happens. But if you have power to the small wire everything inside the car is working fine and it might be a bad intermitant starter problem.
Old Jan 14, 2008 | 06:40 PM
ratfink's Avatar
thanks guys,
I went ahead and changed out the starter with a new one and the car started right up. I guess it was a intermitant starter. Thanks for all your help
Old Jan 14, 2008 | 07:19 PM
ratfink's Avatar
just realized that the radio is displaying CODE on the face. Looked it up in the owners manual but it says to enter the 4 digit code. Does each car have a different code or where can I find the code since I am not the original owner.
dodgerkcj
Jul 2, 2018 11:41 AM
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
