Volvo S70 Trim Levels?
Old Sep 2, 2007 | 04:56 PM
whatman's Avatar
Default Volvo S70 Trim Levels?
Does anybody know where i can see pictures of the different volvo s70 trim levels, drove by one for sale the other day and it looked sweet but am unsure what model it is. had a rear spoiler and was bright red and just said s70 on the back. I really want to buy a turbo model only and want to make sure of it before i take my time to look at it when the car dealers open.
Old Sep 2, 2007 | 06:01 PM
ocean238's Avatar
Default RE: Volvo S70 Trim Levels?
I can't help you if you are in the US but i could tell you what i know about the trim levels in Europe
are you in the US?
Old Sep 3, 2007 | 04:22 PM
Sixdown's Avatar
The ones I know for the US are:
Base
Base SE*
GLT
GLT SE*
T5
The S70R was only available in Europe, so obviously it wasn't an R.
*SE came out in 2000 available on Base and GLT
The Turbo models came with spoilers, so the one you saw was probably a GLT or T5. Depending one where you are, a T5 is usually harder to find.
Every car had an alloy wheel option, so you won't be able to distinguish it by that.
Usually the trim level is written under the rear-passenger light.
Old Sep 3, 2007 | 05:42 PM
Cambridge Volvo's Avatar
Well I am in Canada, and mine is a 98 SE, so your remark about the SE coming out in 2000 is incorrect
Old Sep 3, 2007 | 06:57 PM
S70driver's Avatar
The SE might have been available in Canada in 98 but it wasn't here in the states most likely.
Thusly someone should do a seperate section for the U.S., Canada and Europe. It would give a better picture of the issue at hand.
Also someone could have rebadgged your car as well.
Old Sep 5, 2007 | 08:58 AM
ocean238's Avatar
in Europe we have the following:
SE (2.0 10v, 2.5 10v, 2.5 20v, 2.5T, 2.5D, 2.5TDi)
CD (2.0 10v, 2.5 10v, 2.5 20v, 2.5T, 2.5D, 2.5TDi)
T5 (2.3T)
R (2.3T)
volvo changed 2.5 to 2.4 at 1999 (altho it;s the same engine at 2435cc)
from 1999 there is no more CD level, replaced by XT
Rapidash
Jan 30, 2012 07:53 PM
thecheat
Sep 22, 2010 08:48 PM
BlazeS70
Aug 30, 2009 06:30 AM
casualfc
Oct 6, 2008 09:34 AM
info2x
May 26, 2006 11:11 PM
