what keeps the airbox in place?
I noticed that the box that holds the air filter isn't as stationary as it once was. After randomly coming across pictures I took when I took out the airbox to replace my ABS, I remembered there are plugs/clips on the bottom and one on the side that keep it in place.
Well, the one on the side doesn't look like it's holding anymore. How would I fix this? Does this require a new airbox, or is the clip two sided, one on the airbox side and another on the car side.
Wrong. Again.
rspi claims to have me blocked, so he must not have seen that I already explained this. There is only one post on the driver's side that goes into the fender, as explained above.
yeah, based on this photo I found, http://i88.photobucket.com/albums/k1...m/IMG_4112.jpg, I don't see the prongs of the clip coming thru the airbox mount. Not sure how that would just disappear ...
Are the 1998-2000 V70s the only other cars that have the same airbox. I might venture down to the yard for the part, and having more options would help.
I lifted out the airbox, and the 2 clips are still there intact. The top rubber piece of the clip has gotten compressed over time, and that allows the airbox to move around a little. I assume they're cheap, so maybe I'll just replace them.
The fender post I think is just a guide. I don't think it's meant to clip in anywhere.
Daniel Sendelbach
01-11-2014 08:29 PM
