2004 S60 Airbox (pics added)
Old Jan 7, 2009 | 05:27 PM
LeChasseur's Avatar
Default 2004 S60 Airbox (pics added)
Here's the issue with my S60's airbox. As you can see....the airbox does not have a good seal, and filing down the tabs did not help all that much. Does anyone else have this issue?? Is this a major problem....should I get a new Airbox? That orange color is the foam from the Mahle filter.
If those pics dont show up...here's the link
http://i257.photobucket.com/albums/h...n/100_0679.jpg
http://i257.photobucket.com/albums/h...n/100_0678.jpg
Old Jan 8, 2009 | 09:10 AM
DGBibo's Avatar
Default RE: 2004 S60 Airbox (pics added)
i have the exact car and problem, what i did was go to home depot and bought a reverse vice, its pretty much two wedges of wood with two crews through each, when you loosen the top one and tighten the bottown it pushes things apart. i was able to strech the airbox back to the right form without breaking it. but i gotta tell you that you will encounter this everytime you service your air filter. just a flaw no big deal.
Old Jan 8, 2009 | 04:24 PM
If you remove the lid and trim the 2 tabs from the center hole then stick something between the air box and the fuse box to stable the air box you can slide it back together.
Old Jan 9, 2009 | 09:29 AM
DGBibo's Avatar
what do you mean "trim the tabs"?
Old Jan 9, 2009 | 10:21 AM
Once you pull the air box lid off and out of the way look in the center hole where the tab goes in. You will see 2 little tabs towards the top of the hole. I trim those off.
Old Jan 9, 2009 | 04:04 PM
DGBibo's Avatar
oh yeah i guess i noticed that, good find, looks like i have a project for the 5 degree weekend here in chicago!
Old Dec 20, 2011 | 05:16 PM
peterjax's Avatar
Hi Tech,
I'm hoping you still get an Email alert for this old thread.
Correct me if I'm wrong, but aren't these two little tabs supposed to snap into place in the indentations on the lid tab and therefore help hold the lid in place?
By the way, I broke mine off inadvertently. It was very difficult to get that tab out when removing the cover, so I kept pulling and pulling. Eventually each tab broke. One on the first filter change and the other on the second filter change.
The problem seems to be getting them to snap back in. If the cover warps even a little, those tabs may be nearly impossible to re-engage. Hence breaking them off as you suggest may be the best solution.
Peter
Old Dec 20, 2011 | 08:13 PM
760gle's Avatar
i've just noticed this thread and the photos. to me it looks like some of the plastic has warped. Have you thought of running a heat gun over part of it and re-straightening it?
my 2c worth
Old May 4, 2012 | 09:03 PM
Nichals's Avatar
i have it too, if you carefully fit all 3 tabs in the back before sealing it closed it holds tight for me atleast.
matrim33
May 17, 2013 12:17 PM
v70 2.4t
Sep 10, 2008 01:58 AM
Osamede
Jul 7, 2008 05:48 PM
ibcmoore
Apr 12, 2008 10:51 PM
