Where are the various evap valves on a 2000 S70?
Old Oct 17, 2010 | 04:28 PM
whistman's Avatar
Default Where are the various evap valves on a 2000 S70?
I found the "evap check valve" pictured here clipped to the right side cooling fan shroud (by the battery, under the air intake hose) on my 2000 non-turbo S70.
Most of the sites also sell an "evap purge valve" for that year:
I can't find that latter one. Anyone have a diagram showing the evap system routing, or able to tell me where the latter would be located? Should I replace both at the same time? Car is getting a gross leak code preventing it from passing emissions tests.
Old Oct 17, 2010 | 05:16 PM
Your car should have the top one only. But it also has a canister shut off valve by the canister.
asapatrick
Aug 31, 2013 01:38 AM
mrssjo9
Mar 19, 2010 02:41 PM
pigoo3
Feb 20, 2007 03:49 AM
itsagirl
Jan 29, 2006 06:36 PM
