Wintertime clutch problems
Old Jan 21, 2011 | 10:53 PM
pxl8ed's Avatar
Default Cold weather / winter clutch pedal chattering and squealing
Hi guys, I searched google for this sort of problem but couldn't come up with a good answer.
I imported my 99 S70 T5M from the southern US a couple of years ago and this is its second winter in Canada (it's been cold). When I start the car in the morning and it's totally cold, the engine runs fine before I let the clutch pedal out. When I let the clutch pedal out the engine dips 200-300rpm and a terrible chattering/squealing sound comes from the back of the engine bay/near the tranny. It sounds a lot like a dying bearing. After about 5minutes, when everything warms up a bit, the chattering noise stops, but the engine will still dip about 100RPM as long as I drive the car if I let the clutch pedal out in neutral (this has been going on for about a year now...)
Pretty much my question is: does this sound to you like an issue with the throwout bearing, pilot bearing, or something more serious - maybe a more serious issue with the tranny, or one of the accessory belts? Anything I can try to diagnose more specifically before I take the car to a tech? Thanks!
Cheers - D
Old Jan 22, 2011 | 12:15 PM
pxl8ed's Avatar
I visited my tech today for an alignment and he explained to me that the noise is probably coming from the transmission.
Cheers
- D
gentlejax2
Jun 18, 2012 03:19 PM
mike88
Mar 19, 2010 05:26 PM
garypettengill
Oct 14, 2009 03:55 PM
