wont idle
Old Nov 16, 2010 | 05:50 PM
richrod's Avatar
Default wont idle
my 1999 s70 starts up fine but then idles like sh t. dearler said it was the throttle body had it changed with a used one still the same. some one told me its the ecm. but i am not sure. does a used ecm have to be flashed to work or not. help
Old Nov 21, 2010 | 01:48 AM
Tdog's Avatar
Richrod, mine is a '98 S70 base. I had idle problems for years where it would briefly act like it was going to stall (fuel to rich codes) and this got worse with time. I found a vacuum hose on the right front of the intake manifold that goes to the evap valve (I've seen other setups where this goes to a tree) was badly deteriorated. Dealer recommened replace MAF, air pump, tune up etc. Take a look as replacing a couple dollars worth of hose and couple hose clamps fixed my problem-
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
waltonsauto
Jan 31, 2012 12:40 PM
alex57
Sep 28, 2010 06:48 PM
furball3
Jan 28, 2007 03:31 AM
