"Hisssss" noise form the brake
Old Aug 13, 2008 | 05:55 PM
vy22's Avatar
Default "Hisssss" noise form the brake
I noticed a low "hissss" noise from the brake when the car (99 S80T6) is running. It sounds like a small leak from a vacuum hose. This noise stops as soon as I step on the brake pad and resumes as soon as I release the brake pad. I checked the brake fluid level. It is OK. The brake is working well.
Tried to contact my mechanic, but it was after 6pm and he was closed. Any idea what was the problem? Thanks.
Old Aug 13, 2008 | 07:06 PM
Default RE: "Hisssss" noise form the brake
Sounds like a bad brake booster to me. Pretty common problem.
Old Aug 13, 2008 | 07:35 PM
vy22's Avatar
Hello Tech
Thanks for your prompt reply. Is it still save to drive it for a few more days. I'm pretty tied up until next Tuesday. How many hours will it take to replace it? Thanks.
Old Aug 13, 2008 | 07:57 PM
You should be safe with it like that. Also it should take a couple of hours to either get is swapped or for you to swap it.
Old Aug 14, 2008 | 12:06 AM
vy22's Avatar
Thanks a lot. Tech.
Old Aug 25, 2008 | 10:35 AM
CyDetrakD's Avatar
i just bought a 01 s80 and i have the same hissing problem i see that it is a very common problem obviously if it is stickied but how safe is it to drive under this condition? I just dont want to mess up my new beloved car.
Old Aug 25, 2008 | 09:16 PM
As long as the brakes still feel pretty good you should be fine for a little bit. If the pedal gets hard then change out asap.
Old Aug 27, 2008 | 06:16 PM
CyDetrakD's Avatar
i have a two week 2001 S80 2.9 with stc and my brakes hiss so i have come to the conclusion that it is brake booster since it seems to be a common problem so here is my question where i can find a new one for cheap volvo and fisher tires told me that its 700 for the booster and fishers said 620 so where did you find yours and hopefully for cheap. The labor was 260 is that okay for that type of service? THanks for the help in advance.
TO TECH
how long is a lil bit the breaks are nice soft and responsive at the moment
Old Aug 27, 2008 | 08:01 PM
It might be a day or a year you never know. If the pedal gets hard it is time to replace ASAP.
Johnny Volvo
Sep 2, 2011 11:17 PM
shoter_hellas
Apr 6, 2011 03:51 PM
Beardog
Sep 7, 2010 09:30 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
