02 S80 check engine
Old Jan 24, 2011 | 08:20 AM
jfleming094's Avatar
Default 02 S80 check engine
Just bought this (90K), mechanic who sold it to me had put in a tranny, timing belt and water pump. Check engine light came on, scanner says Overhead ehaust cam timing... Seller will certainly look at it for me, but do I have any reason to worry, should I get this looked at immediately. thanks
Old Jan 25, 2011 | 09:01 AM
NoLifeTilBoost's Avatar
Often when people work on these Volvo motors that dont know them very well mess up the timing. They dont understand how the variable valve timing unit works. The result can be that all the timing marks line up, but the timing still appears to be out. It wont cause any damage, but you might experience loss of peformance, worse fuel economy and bad starting until its fixed.
This thread has some info on setting the VVT unit correctly: https://volvoforums.com/forum/volvo-s80-18/timing-gear-camshaft-position-49525/
Old Jan 26, 2011 | 08:00 AM
Default Thanks
I appreciate your help. This looks like a good forum.
Old Feb 2, 2011 | 06:34 PM
Default pulled the codes
p0014, p0422, p0432
guy I bought from says he will chase these down. Any insight, advice? Love the car, seems to be running fine. MPG about 17 (mostly city)
Old Feb 3, 2011 | 08:47 AM
P0014: Most likely the VVT was set incorrectly. After that it could be a sludged up VVT solenoid or its not happy with the viscosity of the oil in the motor. My money is on the VVT not being set right
The other two codes are cat efficiency. The T6 has two cats and four O2 sensors. Looks like both postcat (aka downstream) O2 sensors are faulty or the cats are not working and need to be removed or replaced. Removing them wont get rid of the code of course, but its cheaper than replacing them.
Old Feb 3, 2011 | 11:02 AM
thanks nolifetilboost. I appreciate it.My daughter is a pretty slow driver, think I have a trans replacement in my future?
Old Feb 3, 2011 | 12:55 PM
Depends on the history of the transmission the mechanic put in there moreso than anything else I think. How is the fluid condition right now? If its a T6 then remeber when you goose it the tranny will be at the absolute max torque that it was designed for. My advise would be to stay up on fluid changes. Maybe do drain and fill + filter change every 15K miles/6months or so. Ive been using Dexron VI in my '99 T6 to good effect. Your 02 may have a different tranny however so verify that Dexron is appropriate
You may have an expensive cat converter repair on the horizon though. $200/cat easy + labor.
Bet the P0014 taken care of as it will affect peformance and gas mileage.
MissingJenn
Oct 29, 2009 07:41 AM
jaby
Oct 23, 2008 05:44 PM
jwardmls
Oct 23, 2008 11:01 AM
gratefulvolvo
Dec 9, 2007 04:30 PM
rhgibson
Apr 2, 2006 12:16 AM
