1999 S80 DTC P0123 P0228 P0120 P0118 P0124 P0103. etc
Old Oct 15, 2008 | 11:36 AM
edtech1300's Avatar
Default 1999 S80 DTC P0123 P0228 P0120 P0118 P0124 P0103. etc
I need a little advice on my 99 s80 170,000 miles, first off I know the 99 s80 is a real POS so what my goal is, Dump the money into parts one last time and I do all the work. From there run it until the wheels fall off.
So here are my OBD codes
-P0123 “Throttle/Pedal Position Sensor/Switch “”A”” Circuit High”
-P0228 “Throttle/Pedal Position Sensor/Switch “”C”” Circuit High”
-P0120 “Throttle/Pedal Position Sensor/Switch “”A”” Circuit
-P0118 Engine Coolent Temp Circuit High
-P0124 “Throttle/Pedal Position Sensor/Switch “”A”” Circuit Intermitting”
-P0103 Mass or Volume Air Flow Sensor Circuit High Input
-P0335 Crankshaft Position “”A”” Circuit”
-P1618 Fault in Lead Between AW 50-52 and Motronic 4.3 (MIL Requested)
[hr]
Well there are my trouble codes. Now as far as symptoms I can see 1. My coolant temp sensor is sunk all the to the cold side and when I read live data the temp is at -44*F. 2. My tranny seems to get stuck in gear, kinda. If I go up a real steep heal I cant pick up speed and the tack stays in the lower RPMS (this only happens sometimes)
3.The car seems to be running a little bit rich (I can smell gas when I start the car)
4. Sometimes the first start of the day gives me a little bit of trouble
I am assuming I should just replace all the sensors above but before I can do that I have a few questions
1.Where are they all located (I know where the MAF sensor is as far as the rest I dont have any idia)
2. I have know idea about code P1618 if you could guide me in the right direction on this code that would be grate
3.Could it be the sensors are not bad but something else is causing the to malfunction IF SO what and where
ANY HELP WOULD BE GRATLY APPRECIATED thanks
Old Oct 15, 2008 | 11:54 AM
Default RE: 1999 S80 DTC P0123 P0228 P0120 P0118 P0124 P0103. etc
Are you in the U.S. market?
If so make sure the throttle body recall software has been done.
If it has then you might want to have the Dealer look at it the throttle body might be bad.
RRTEC
Sep 30, 2014 09:13 PM
zloetakoe
May 28, 2011 07:29 PM
boxpin
Aug 12, 2010 12:28 AM
hilda95
Apr 4, 2010 02:42 PM
breton
Jun 6, 2009 01:06 PM
