1999 s80 Sunroof won't close
Old Oct 17, 2010 | 10:46 AM
bretterson's Avatar
Default 1999 s80 Sunroof won't close
Is there a way to manually shut the sunroof in the 1999 Volvo s80?
I removed the light cover and panel above the rear view mirror, and I can see the motor, but no area to crank...
Do I need to remove the motor to be able to close the sun roof manually?
Or how should I do this?
P.S. The motor and switch are bad... so manually is the only option at this point.
Old Oct 17, 2010 | 02:44 PM
Grendel's Avatar
Are you getting an "Alarm System Service Required" message?
Old Oct 17, 2010 | 07:58 PM
bretterson's Avatar
No alarm system message, I have been digging around on the internet... I tried the key in the door three times trick... no go. I think its just a bad motor... I was in hopes of a manual closing option, but my research is turning up with no results...
I have read a few things about older models that had an area to manually crank it shut, but I am not reading anything about this year and model.
I removed the light panel and was able to see the motor, but nothing more.
Old Oct 18, 2010 | 02:59 PM
Grendel's Avatar
That sucks man. This kind of stuff makes me scared to use my sunroof
Old Oct 19, 2010 | 06:32 AM
bretterson's Avatar
I took it by the garage I go to and they quoted me between $580 - $600 to repair the sunroof... its cheaper than I was expecting... but to replace a motor and switch, they said it would take 3 hours... does that seem accurate?
Old Oct 19, 2010 | 03:29 PM
Grendel's Avatar
I would be very surprised if it really takes that long.
Old Oct 19, 2010 | 11:29 PM
clyncross's Avatar
i dont know if this helps or not, but the volvo dealer i took my 99 s80 to told me that my security system was no good and one of the things it will do is lock up the sunroof to where it wont close or open if the system decides to malfunction. may not be your cars issue, but it may be worth a shot looking at the security system too...just in case its not the motor. my dealer quoted me about 600 bucks for the security system to be fixed. so far not a problem for me, but im sure it will be. this car hasnt been anything but a problem.
Old Oct 20, 2010 | 07:23 AM
bretterson's Avatar
I am starting to see that about this one, fortunately its all stuff I don't need... The engine is sound, but windows, sun roof, etc are a problem
Old Oct 22, 2010 | 01:15 AM
re100005's Avatar
I had a problem with my sunroof not closing to the proper position. It would think it was closed but still slightly open. The dealer apparently got the computer to 're-learn' it's open closed positions. Cost was .5hrs shop rate.
timtatum
Jan 8, 2025 09:44 AM
painterman
Volvo C30
Mar 1, 2015 11:56 AM
Mickeyj1966
Dec 18, 2011 03:36 AM
OME
Jun 23, 2011 10:06 PM
backslide
Oct 21, 2006 04:14 PM
